Warning message
How to set a timeout for the Execute object
May 30th, 2003
I want to push a message to IP phone and then want the message to disappear from the display after a certain time.
How can it be done.
Any help will be appreciated.
Shyamal
jshepard Tue, 06/03/2003 - 10:55
  • Cisco Employee,
Include a refresh header within the http
example
refresh:5:InitServices
This will after 5 seconds refresh the screen to the initservices uri
shyamalbhowmik Mon, 06/09/2003 - 02:06
I am using the CiscoIPPhoneExecute object to push the message.
Using LWP::UserAgent in perl i am pushing the message to the IP phone.
Let me know if anymore help required
Shyama
ashley.lin Fri, 07/25/2003 - 13:06
hi Shyama,
I'm also trying to push a message to a phone using the CiscoIPPhoneExecute object and I'm also using LWP::UserAgent in Perl. However, I have not been successful in pushing the message to the phone. If possible can you show bits of the code you used to achieve this, or explain more in detail the logic flow of the statements so I can see if I'm doing anything wrong?
Thanks!
