Warning message
ISDN PRI: TEI_ASSIGNED status in layer 2
Jun 2nd, 2003
My working PRI line says TEI_ASSIGNED at Layer 2 upon issueing the SHOW ISDN STATUS and doesn't take incoming calls from remote router
jolmo Mon, 06/02/2003 - 03:16
  • Silver, 250 points or more
You can't take calls because Layer 2 isn't in right state. It should display MULTIPLE_FRAME_ESTABLISHED at Layer 2.
For more information refer to 'E1 PRI Troubleshooting':
http://www.cisco.com/en/US/tech/tk713/tk584/technologies_tech_note09186a00800f9e3a.shtml
'E1 PRI Troubleshooting Flowchart':
http://www.cisco.com/en/US/tech/tk713/tk584/technologies_tech_note09186a00800a70fc.shtml
and 'E1 Troubleshooting':
http://www.cisco.com/en/US/tech/tk713/tk584/technologies_tech_note09186a00800a70fb.shtml
These pages offer very useful flowcharts for troubleshooting PRI lines.
P.S: I'm also managing PRI lines, and recently installed a new one. When I checked it, I also saw Layer 2 TEI_ASSIGNED. Problem came from Telco provider. They solved it later.
deilert Mon, 06/02/2003 - 04:09
In the US it should be multi frames established. If you are not in this state it is a carrier problem . Outside the US this is the normal state prior to placing a call.
