Warning message
ios ids
Jun 2nd, 2003
10.1.1.0/24(e0) | r1 | 192.168.1.0/24 (s0)
i'd like to enable r1 cbac & ids
I configured cbac as below.
By the way, do not know whether must apply ids direction how.
1.Telnet & web traffic that enter to inbound from outside using ids monitor do wish to .
2.Web traffic that leave interior wishes to do inspect.
r1
ip ins name fw tcp
ip ins name fw http
int e0
descrytion internal
ip address 10.1.1.254 255.255.255.0
ip access-group 100 in
ip ins fw in
int s0
descrytion external
ip address 192.168.1.254 255.255.255.0
ip access-group 110 in
access-list 100 per tcp 10.1.1.0 0.0.0.255 an eq 23
access-list 100 per tcp 10.1.1.0 0.0.0.255 an eq 80
access-list 110 per icmp any any
access-list 110 den ip any any
ywadhavk Tue, 06/03/2003 - 05:28
  • Cisco Employee,
The 'ip audit' i.e. the IDS monitoring should be applied to the outside interface in the IN direction. So in your case, the ip audit rule should be applied to the int s0 in the IN direction.
Please use the below guide for procedure to configure the IOS IDS.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/ftrafwl/scfids.htm
Hope this helps,
yatin
