Warning message
Forward udp broadcasts to subnet
rsissons Wed, 06/04/2003 - 16:05
  • Bronze, 100 points or more
Yes, you can use the subnet broadcast address as the helper address.
thisisshanky Wed, 06/04/2003 - 20:49
  • Purple, 4500 points or more
For specific ports, use,
Router(config)#ip forward-protocol udp 6614
Forward the broadcast as a directed broadcast on to the subnet. Say for example if subnet is 192.168.1.0/24, then the helper-address command would look like, "ip helper-addres 192.168.1.255"
When you enable helper-address 8 default udp ports are always forwarded. You might want to disable them.
no ip forward-protocol udp bootpc
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp tacacs
I tried using the broadcast address (172.17.255.255) as the helper address but I did not see any UDP traffic being forwarded. If I used the IP address the VPN client gets from the vpn pool (172.17.1.5), I could see lots of UDP traffic. I also tried using 172.17.1.255 as the helper address with no success.
Any ideas?
