Warning message
How to configure a span port on switch 3524 with two vlans
Jun 5th, 2003
I am trying to configure span port on 3524 which has two vlans
how should i do that , i need to different span port for diferent vlans or one span port for two vlans.
jasonrakers Thu, 06/05/2003 - 09:31
I think the 3500s can only have one span session active at a time. To create a span session on your 3524, enter the interface desired for the destination (where the sniffer is attached) and do a "port monitor ". can be a physical interface or a whole VLAN. You can only do one source VLAN at a time.
Hope this helps.
t.baranski Thu, 06/05/2003 - 18:02
  • Bronze, 100 points or more
Per http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a00800d9d3d.html#xtocid25 :
"A SPAN port cannot monitor ports in a different VLAN, and a SPAN port must be a static-access port. You can define any number of ports as SPAN ports, and any combination of ports can be monitored."
So it appears that 3500s can have multiple SPAN ports simutaneously.
