Warning message
Pix Static and route-maps
Jun 5th, 2003
Is there any info as to whether PIX is going to support route-maps with the static translations, for example one inside IP can have two or more static translations to the different IPs on outside interface.
Route-map would define the traffic direction and, therefore the proper static to use. It's been done for IOS and static NAT.
Also this topic has been mentioned here not that long ago and apparenty the feature (not the route-maps but port redirection from two outside IPs to a single inside) is suppose to appear in 6.3.2 but it will work only for inbound connections because without route-maps there is no way to identify which static to use for outbound connections.
mhoda Thu, 06/05/2003 - 20:19
  • Silver, 250 points or more
Sorry ! There is no plan for route-map in version 6.3.2. Please talk to account team for feature request. Thanks,
Mynul
