Warning message
why my pix535 only support 3 static outside ?
Jun 6th, 2003
On the other side of pix 535 outside interface ,the router`s interface ethernet
,with the "show arp "command,i only find three pix 535 static ip address with
pix535's outside interface mac address,but have other static ip address no assign a mac, there only 00-00-00-00 display,why?
thanks!
mostiguy@netnum... Sat, 06/07/2003 - 07:17
  • Silver, 250 points or more
If there had been no recent communication to those ip addresses, there may not be an arp entry as it may have timed out. if you ping those static ip addresses, and they are in use, they should appear in the arp table
mhoda Sat, 06/07/2003 - 14:16
This is kind of strange ! With proxy arp on, you should be able to see the mac of outside for all the static translations. I would check to see if there is any address conflictions? Thanks,
Mynul
lprong Sun, 06/08/2003 - 04:35
Hi,thanks everybody,i found my static command config wrong,
now system is ok.
thanks!
