Warning message
fa0/0 administratively down when I add "service-policy:
Jun 7th, 2003
I have 2621 and IOS 12.1(5)T9 with IP/FW/IDS. the fa0/0 interface become administratively down when I add a service-policy in the interface even nobody issue the command "shutdown". everything fine if I remove the "service-policy" command from the interface.
1. message. showing this message when I add the service-policy command.
00:46:50: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
00:46:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
2. configuraiton. I just added the "service-policy router2" in the existing configuration.
class-map match-any router2
match access-group 100
class-map match-any http-hacks
match protocol http url "*readme.eml*"
match protocol http url "*.ida*"
match protocol http url "*cmd.exe*"
match protocol http url "*root.exe*"
policy-map mark-inbound-http-hacks
class http-hacks
set ip dscp 1
policy-map router2
class router2
bandwidth 3375
class class-default
fair-queue
interface FastEthernet0/0
description Ethernet to INTERNET
ip address x.x.x.x 255.255.255.248
ip access-group xxxxxx in
ip access-group 102 out
no ip proxy-arp
shutdown
speed 10
full-duplex
service-policy input mark-inbound-http-hacks
service-policy output router2
traffic-shape group 101 5999999 749992 749992 1000
Any idea or tips ?
spremkumar Sun, 06/08/2003 - 01:59
  • Red, 2250 points or more
hi choi
for my info hv u enabled CEF on this router??
in the config posted by u shutdown command is also ther..chek it up once again..
regds
prem
