Warning message
mrtg process stall
Jun 9th, 2003
Dear sir,
My switch is Cat4k with SuperEngineIII. There is a MRGT utility connect to the Switch (it's platform is linux). There are 3 3com switches and 1 cat3548 connect to the Cat4k. There is a curious problem:
My mrtg process point to the 3 3com switches would stall(just like die) sometimes. But the mrtg process point to 3548 works normal. If i replace the Cat4k with another 3com switch, the mrtg process would not die then.
I need to know why or How I can troubleshooting this problem.
There is no special configuration on cat4k but
snmp-server community xxxxxxx RO
I have only 1 vlan on the cat4k.
Thank you so much!
Sha
didyap Fri, 06/13/2003 - 08:53
  • Silver, 250 points or more
Am not sure if this is a problem with the Cat4k since Cisco switches ususally work well with MRTG. You could try re-installing the MRTG process again or check for known bugs with this issue.
