sghosh Tue, 06/10/2003 - 09:14
What kind of simulator are you looking for ? Do you want a packet generator to test some connections ? You can use a program called "httpget" to generate some http packets.
Sujit
m-karakasians Tue, 06/10/2003 - 10:28
I would like something like the router simulator. To test config changes. I do not have a spare PIX to run tests. I want to try the vpn setup and some other things but do not want to play on the one protecting my network.
