Asbjoern Hoejmark Wed, 06/11/2003 - 13:27
Redistribution can be controlled in several ways, and which one is 'best' really depends on what you're trying to achieve. One of the most flexible ways is by using route maps, such as the following example (off the top of my head):
router ospf 1
bla. bla.
router bgp 65101
redist ospf 1 route-map SOME-ROUTES
route-map SOME-ROUTES permit 10
match ip address 10
access-list 10 deny 10.0.0.0 0.3.255.255
access-list 10 permit 10.0.0.0 0.255.255.255
access-list 10 permit 172.16.0.0 0.0.255.255
You can also match on tons of other stuff, such as metrix, next hop etc. in the route map
-A
ERIK LAWAETZ Wed, 06/11/2003 - 13:40
A generic config:
router bgp 99999
router ospf 99999
redistribute bgp 99999 subnets route-map bgp2ospf out
route-map bgp2ospf permit 10
match ...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_c/1cprt1/1cospf.htm#5439
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:OSPF&s=Implementation_and_Configuration
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:BGP&s=Implementation_and_Configuration
The important thing here is that you need to determine which routes you want to redistribute and how to match them in the route map, be it based on AS number of specific IP prefixes.
You should be very restrictive about what you redistribute into your IGP from BGP!
