Warning message
Name on Dialer Map statements?
Jun 15th, 2003
I have a question about the NAME portion of the dialer map statement.
ie. dialer map ip 10.1.1.1 name RouterA broad 5551212
What exactly does the 'name RouterA' do for me? And before everyone
jumps up and says that this is the name used for ppp authentication
purposes, I ask, have you tried this? I have a lab with ISDN circuits
and regardless of what I put for name xxxxxx, my authentication
completes successfully. If I leave the 'name' part out altogether, I
still authenticate. In my experience in the lab, it seems to have no
value whatsoever. Does someone know what this is really for? And if
so, is there some little test I can run that will show me what this is
for so as to convince myself that this actually does something? The
only purpose to me seems to be to put a comment in the map statement to
indicate who we are talking to.
l.mourits Mon, 06/16/2003 - 02:12
  • Silver, 250 points or more
As far as my experiences go, I can tell you that it is used for at least two things......, number one is that the name portion is for incoming calls to select the appropiate dialer map for authentication, and number two is that this name is undeed used for the authentication used. But, you have to remember that if you are using PPP with CHAP it is possible to have one-way or two-way authentication, so, if using one-way authentication the name portion will not be used if you are initiating the connection, instead, only the username password in global config would be used.
Hope this helps
makchitale Mon, 06/16/2003 - 17:34
When connecting to a peer using dialer maps, the router uses the dialer map to bind the call. Therefore, the IP address and username of the peer are bound. If the wrong IP address or name is in the dialer map, then the call will connect but IDEALLY should not be able to pass traffic.
The debug ip packet command will indicate that the "encapsulation failed".
Can you please post the following debugs on you test call:
deb isdn q931 / deb ppp nego / ping x.x.x.x (peer ip address)
Thanks, Mak.
