Warning message
Chassis Serial number
Overall Rating: 5 (1 ratings)
lewong Mon, 06/16/2003 - 18:04
  • Cisco Employee,
You are correct.
The Cat 4006 output does list the chassis serial number.
In the case of the 3548.. you want to grab the system serial number not the motherboard serial number.
See below:
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes
of memory.
Processor board ID FAA03xxxxxx, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:30:80:96:30:00
Motherboard assembly number: 73-3904-08
Power supply part number: 34-0851-02
Motherboard serial number: FAAxxxxxxx
Power supply serial number: NONE
Model revision number: A0
Model number: WS-C3524-XL-EN
System serial number: FAA03xxxxxx <---- This one!!
Configuration register is 0xF
Cheers
LW
gahlberg Tue, 06/17/2003 - 07:27
Is there any way to match (for ex. with a Catalyst 2948) the Serial Number that is on the sticker on the switch with the actual system serial number. For example, if I have a switch off-site and can't see the sticker. How can I go about finding that sticker serial number. As an example, (for one that I know) system serial number = JAB04470CYD; and the sticker serial number = FOX04372931. Is there a database online to be able to retrieve this information.
Geoff
