Warning message
Monitoring PIX Performance
Jun 17th, 2003
we want to monitor periodically the memory utilization of our PIX firewalls. I did not find any recommendation what amount of free memory in percentage should be the threshold to look for.
In the TAC documentation it is mentioned that the free memory should not change, if at all, during normal operation. But I am missing an actual number to use as threshold.
Can somebody help me with this?
Your experience and information regarding other important performance parameters like cpu utiliziation etc. is very much appreciated.
Thanks for your help and best regards
Overall Rating: 5 (1 ratings)
umedryk Fri, 06/27/2003 - 11:19
  • Bronze, 100 points or more
Hi Sharafi,
I dont think so the memory utilization of PIX will be any standard.
It all depends on your network. Keep observing and after sometime
you can settle down on a speicific value of utilization.
There are no commands on the pix that will give you CPU utilization.
a router running NAT with large numbers of NAT translations active will
see high cpu at interrupt level.
This command will be useful: router#show proc cpu
shannong Fri, 06/27/2003 - 11:35
  • Silver, 250 points or more
Percentage free will vary from one model to another. Even the same models may have different amounts of RAM. For example, the Pix 515 comes with 32MB or 64MB. Other variables affecting RAM usage:
The number of interfaces
The number and length of ACLs, especially with TurboACL
Use of the PDM
Use of stateful failover
The number of free blocks is also very important to a Pix. The pool of blocks are allocated at boot time for connections and translation information. These are important to track as well. You can have 50% free memory and have a problem due to insufficient free blocks for new connections and logging.
I suggest you monitor free blocks and free memory over time. The baseline is dependent on your business. If you sell Christmas trees, the seasons affect your baseline a lot. At least monitor your firewall for a month during a "peak" and "normal" period to establish your own baseline.
From a command line, you can use [show cpu usage], [show mem], [show perfmon] and [show pdm history] to monitor these values. Of course, you can use the PDM to monitor these things as well with a timeline graph.
You can use SNMP to poll the CPU, blocks, and memory utilization if you're running Pix 6.2+. Then you can graph it and perform threshold checks with an NMS. MRTG can graph these things easily for you.
-Shannon
