Warning message
HP iPAQ H5450 : Wlan : can iPAQ WLAN adapter connect to a Cisco AP with LEA
Jun 18th, 2003
I wonder if an HP iPAQ H5450 Wlan can connect to a Cisco AP with embedded WLAN card. I am using the ACU client, but it keeps looking for the Cisco 350 Adapter. Is there an update available...
white_adam Sun, 06/22/2003 - 18:04
The release notes for the new ROM update for the 54xx series lists;
- Adds LEAP authentication client support (requires firmware update)
Now I don't have a 54xx model so I cannot verify that this works, but it's worth a shot.
hvincke Sun, 06/22/2003 - 22:25
I've installed the new Rom version, and i tryed with the LEAP authentication.
At home it is working fine on AD, but there I work with Belkin AP's.... At work, J & J, there are only secured Cisco AP's available...
Thanks for your response,
Kind regards..
gold78 Mon, 06/23/2003 - 11:22
Have you installed the firmware update for the wlan card too?
There do you got it from?
HP says they haven't released it yet.
hvincke Tue, 06/24/2003 - 01:35
I did replace the rom of the iPaq not of the Wlan card, that is correct...
white_adam Mon, 07/07/2003 - 16:02
The new WLAN firmware has been released.
ftp://ftp.compaq.com/pub/softpaq/sp...000/SP24574.exe
----small snippet-----
PURPOSE: Recommended Update
SOFTPAQ NUMBER: SP24574
SUPERSEDES: None
EFFECTIVE DATE: July 2, 2003
CATEGORY: ROMPaqs/BIOS and Firmware
SSM SUPPORTED: No
PRODUCT TYPE(S): Handhelds
PRODUCT MODEL(S): iPAQ h5400 Series Pocket PC
OPERATING SYSTEM(S): Microsoft Pocket PC 2002
LANGUAGE(S): English
ENHANCEMENTS:
FIXES:
- Enables connect with a WLAN Access Point that supports both 802.11b and
802.11g
PREREQUISITES:
- ROM update v1.11.xx must be installed first before the WLAN firmware
update
is installed. DO NOT install the WLAN firmware update before installing
ROM update v1.11.xx.
- Synchronization software such as Microsoft ActiveSync 3.5 or later
------end small snippet------
Does the fact that there were no posts after this message indicate that the new firmware worked for you? I have an iPaq 5450 with built in wireless and I have updated the firmware much to the detriment of all my data (frimware required a device frimware update) and I still cannot connect to an Aironet 1200 requiring LEAP to access? Does anyone have any helpful information here? I also updated the drivers for a Tablet PC tc1000 with built in wireless and guess what? It doesn't connect either. Is there a setting on the device required in order to allow non-Cisco cards to connect?
hvincke Thu, 08/21/2003 - 00:04
No it does not work, i thank everybody for all replies, but i guess that i will need to buy the PCMCIA expension slot with a Cisco Wireless Aeronet card...
Kind regards,
Hans
