Time to live ended
Jun 23rd, 2003
I have 2 router (1700-1700) connected with a leased line within 5 km.
When i send a ping packet, the remote router sends an icmp packet (time to live expired).
Whats the problem?
Thanks.
mark-obrien Mon, 06/23/2003 - 02:58
  • Bronze, 100 points or more
It could be that neither router has a routing table entry for the destination address you are pinging, and they each have a default route (or other short matching route) pointed to the other. This would cause a routing loop and a TTL expired message.
Check each router for the route to the address you are pinging.
Mark
mark-obrien Mon, 06/23/2003 - 04:48
Also, do a traceroute and see if there is a loop.
