Warning message
EIGRP stub and summary considerations at remote sites.
Jun 23rd, 2003
I have many remote sites in a hub and spoke arrangement. EIGRP is running and I would like to have the simplest routing table on the remote sites as possible and keep the serial links to them as quiet as possible concerning routing changes.
What is the best way to do this? Do I configure each remote site as a stub with auto summary? The remote site router doesn't need the entire routing table, it only needs to know to go up its serial link to route for everything other then its local lan.
thisisshanky Mon, 06/23/2003 - 11:53
  • Purple, 4500 points or more
You can inject a default route to each stub using a prefix list or distribute list and redistribute command.
On the hub.
ip route 0.0.0.0 0.0.0.0 null 0
router eigrp 45
redistribute static
default-metric 1544 2000 255 1 1500
distribute-list 1 out
access-list 1 permit host 0.0.0.0
X is the interface number and Y is sub interface number (if applicable)
ruwhite Mon, 06/23/2003 - 12:13
  • Gold, 750 points or more
You should, of course, make this a floating static if you already are learning a static from elsewhere (like an internet connection).
Russ
