Warning message
1700 Router does not boot
I having problems with one of my routers, every time I try to boot the router I get an error about the flash. I think that my config file that was on the flash was erased. I want to find out how can I boot my router from a tftp or any other solutions to get the boot configuration back on it. The confusing part is that I’m getting a lot of character, from the router every time I turn it on in the HyperTerminal, even when I have the right configuration in the Hyper Terminal for the Cisco equipment.
mainesy Wed, 06/25/2003 - 12:27
Did you happen to change the configuration register? Reboot the router and check at bootup to see what the configuration register is set at. You may need to drop your Hyperterminal bits per second rate down to 2400. I seem to remember having a problem similar to this with an AS2509 and that is what I had to do. Good luck.
Josh
