Warning message
which "lane" command correct?
Jun 24th, 2003
  • Bronze, 100 points or more
Dear all,
I have seen two types of commands to configure LEC on Atm lane modules.
"lane client 1 ELAN1" and "lane client ELAN1", in which for first command "1" is VLAN-id. Which is correct command?
Thanks in advance..
Regards...
Ashok.
gmarogi Tue, 07/01/2003 - 08:16
I think both of them are correct. The first one is used on a switch to bind a vlan to the ELAN. The second one is used on a router which can route between different ELANs configured under different sub-interfaces.
