Warning message
AP1200, WGB350 Radio Power?
Jun 25th, 2003
When I fixed AP1200 with 100mW (20dBm) and watched ACU in notebook as near as possible between AP and notebook, -10dBm signal strenth is indicated by ACU site survey menu as SNR (80dB) and noise level (-90dBm). I understand -10dBm means 10mW. How can I understand the "-10dBm" at the receiveing party.
Next, I change the antennas to Parabolic (21dBi) at AP1200 and the Yagi (13dBi) under the same condition, but there is no changes the receiving signal strenth as -10dBm.
At WGB350, I fixed the tx power as 100mW, but I find the strenth out is 0dBm in the link test menu. Please explain these issues.
We need the more system magine in using outside and insufficent Line Of Singht condition (campus fense video surveillance application).
p4jkran Wed, 07/09/2003 - 15:33
-10dBm is an incredibly strong signal my friend.. its like a 1000 watt stereo right next to your ear.. At such close ranges you are not going to see any difference between antennas.. You need to have some distance between the AP antenna and the recieving notebook (like 100 meters) before you can compare antennas.
In the real world, noise floors hover at about -89 db or so.. any signal stronger than -69 db is considered great.. basically you are looking for a 20 db s/n ratio here and you are golden.
derwin Mon, 07/14/2003 - 21:41
  • Cisco Employee,
on the client what version of ACU NDIS and firmware are you running,
in older versions if you have a mis match combination of these 3 then you will get misleading signal strength
Previous post is 100% correct though you do not have -10dbm you would not have your card still functioning at that level signal maybe even see smoke :)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
