Warning message
DIAL-IN and Site-to-Site ISDN with one PRI
Jun 26th, 2003
I have the following config on my PRI Interface:
interface Serial1/0:15
ip address 192.168.0.1 255.255.255.0
ip helper-address 172.22.22.1
encapsulation ppp
dialer idle-timeout 180
dialer wait-for-carrier-time 60
dialer map ip 192.168.0.11 name router1 12345
dialer map ip 192.168.0.21 name router2 98764
dialer map ip 192.168.0.22 name router3 462842
dialer-group 1
isdn switch-type primary-net5
peer default ip address dhcp
compress stac
ppp callback accept
ppp authentication chap pap
ip route 10.100.100.0 255.255.255.0 192.168.0.11
ip route 10.100.101.0 255.255.255.0 192.168.0.21
ip route 10.100.102.0 255.255.255.0 192.168.0.22
People can Dial in With ther PC an ISDN Card and get an IP Adress from the DHCP-Server from the pool 192.168.0.200 to 192.168.0.230.
Teh three Router are Cisco 801 and can build up a Dial Connection to the router.
I want to configure the Router links with a small network:
192.168.1.0; 192.168.1.4 and 192.168.1.8
The RAS User will still in future use the Pool 192.168.0.0
I have tried to use the config:
no ip address
encapsulation ppp
dialer pool-member 1
interface Dialer 1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp callback accept
interface Dialer 2
description Router 1
ip address 192.168.1.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer-group 1
dialer remote name Router1
dialer string 12345
ppp authentication chap callin
ip route 10.100.100.0 255.255.255.0 192.168.1.2
If I use this config only the Dialer 2 for the Site-to-Site connection works.
If I delete the Dialer 2 ant there is only one Dialer in the Dialer Pool 1 the Dialer 1 for Dial In works.
Can anybody help me with this problem?
Is there maybe a other solution to solve this problem?
Thanks for your help!!!!!!!
Best regards
Peer
makchitale Thu, 06/26/2003 - 18:23
  • Silver, 250 points or more
1)When using dialer profiles, dynamic binding of call to the correct dialer interface is critical or else the call will fail....
2)Within Dialer Profile, there is no method to configure a generic dialer profile (or even a default profile) for a group of users that share the same characteristics. Each user must have its own profile.
Depending on the number of dialin users, we can use combination of virtual profiles (for dialin) & dialer profiles (for dial out).....unless we want to create multiple dialer interfaces for each dialin user.
For you setup to work please refer to (your exact requirement)
http://www.cisco.com/warp/public/793/access_dial/pri_dialin_6435.html
NOTE: In the above for dialin, the binding can be done based on "dialer remote-name xxx" or "dialer caller" or "dialer called"
For info on Virtual-Profiles:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios112/vprof.htm
For more info on dialer-Profiles:
http://www.cisco.com/warp/public/129/23.html
Thanks, Mak.
pkohlstetter Sun, 06/29/2003 - 08:05
I have tried to find some informations about Virtual-Profiles and i have read the page "Info on Virtual-Profiles".
But I have no idea how to configure virtual profiles for dial in.
Can you give me an sample config or a webpage with this info.
makchitale Sun, 06/29/2003 - 09:19
Create a virtual-template interface so that a dynamic virtual access interface is cloned/ created for every new dialup call....
virtual-profile virtual-template 1 <==global command
interface virtual-template 1
ip unnumbered ethernet 0 or loopback0
encapsulation ppp
NOTE: this holds good if we are going to apply common configs to each dynamically created virtual-access interface, however if we need different values (say like idle timeout for different users) then we need to go with dialer profiles.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt8/dafvrtmp.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_c/dcvprof.htm
Thanks, Mak.
pkohlstetter Sun, 06/29/2003 - 22:55
I have tried to build a virtual-template Config with my Test-Router cisco 1720.
But I can not dialin with the virtual template. I try to get a connection from my PC with the User koli. But the call is not accepted.
The command "encapsulation ppp" is configured on Interface virtual-template 1 but it is not shown. Is this ok or iss this a bug.
Can anybody find the problem in this config?
Building configuration...
Current configuration : 1815 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname blue
aaa new-model
aaa authentication ppp default local
aaa authorization network default local
enable secret xxx
username koli password 0 xxxx
memory-size iomem 25
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
isdn switch-type basic-net3
interface Loopback10
ip address 192.168.200.1 255.255.255.0
no ip route-cache
no ip mroute-cache
interface BRI0
description BRI
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
interface FastEthernet0
description LAN Test
ip address 10.100.100.61 255.255.255.0
speed auto
interface Virtual-Template1
ip unnumbered Loopback10
no peer default ip address
interface Dialer1
ip address 192.168.100.1 255.255.255.0
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer-group 1
peer default ip address pool blue
ppp authentication chap ms-chap callin
interface Dialer5
ip address 192.168.250.1 255.255.255.0
encapsulation ppp
dialer pool 1
ip local pool blue 192.168.100.100 192.168.100.110
ip local pool blue2 192.168.200.100 192.168.200.110
ip classless
ip route 192.168.100.0 255.255.255.0 Dialer1
no ip http server
ip pim bidir-enable
access-list 115 remark Tarffic VPN
access-list 115 permit ip 192.168.118.0 0.0.0.255 any
access-list 115 deny ip any any
access-list 116 permit ip 10.100.100.0 0.0.0.255 any
access-list 116 deny ip any any
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
password xxx
