Warning message
Router 1760 and WIC-1T
Jun 27th, 2003
I have two routers 1760 serie with a WAN card WIC-1T inserted in slot 0.
Unfortunetly, I cannot use the command "controller E1 0/0" in order to configure the source of the clock.
Nor can I use the command "sh controller E1".
The command "show diag" tells me that the card WIC-1T has been recognized by the router.
Where is the problem ? Is there a special image that I should use ?
My IOS image file is : c1700-sy-mz.122-11.T8.bin
Thank you for your reply.
lgijssel Fri, 06/27/2003 - 05:51
  • Red, 2250 points or more
If you intend to use a WIC-1T as controller for a 2Mb G703 link, you probably have the wrong module. The WIC-1T can only be used to connect to a conventional leased line. It will show in the config as int serial ..
To connect a structured or unstructured G703 you will need something like the VWIC-1MFT-G703. Please have a look at the following link to the product specs for these modules:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088715.html
Leo
