Warning message
rjackson Fri, 06/27/2003 - 12:02
  • Bronze, 100 points or more
Its a reversion to old technology. The Cat port can only run half duplex. The users on the hub will share a collision domain. It will work, its not too bad for slow low use devices. It takes a cross over cable or the hub might have an uplink port that will do the cross over. It might have a button that controls if the port is crossed over or not.
ERIK LAWAETZ Sun, 06/29/2003 - 13:41
And you shouldn't run Spanning Tree PortFast on the port connected to the hub in case someone loops two ports on the hub.
milan.kulik Wed, 07/02/2003 - 05:39
  • Red, 2250 points or more
spanning-tree portfast bpduguard
is necessary to prevent a loop problem in the case someone loops two ports on the hub.
Disabling Spanning Tree PortFast is not enough.
Milan
