Converting 3550 from SMI to EMI
Jun 30th, 2003
Hi All,
we changed a 3550 SMI Switch from SMI to EMI and it works as an EMI.
But if I display show version - there it still shows SMI.
Any Answer to this?
Regardsa
Richard
Overall Rating: 5 (1 ratings)
bbranch Mon, 06/30/2003 - 05:44
  • Silver, 250 points or more
This is set when it ships from Cisco and does not change when you upgrade.
You should refer to the image name to determine if the switch is EMI or SMI, an EMI image contains a 5 (C3550-I5Q3L2-M) whilst an SMI image contains a 9 (C3550-I9Q3L2-M)
richard.werner Mon, 06/30/2003 - 05:44
Please ignore - I found the solution from a previous request.
The model number will always reflect what the switch shipped with from Cisco i.e. in your case SMI. You can tell that you are running EMI because the image you are loading has the number "5" as in C3550-i5 indicating EMI. If it was SMI it would be C3550-i9.
Richard
