File on Unity to strip digits on inbound calls
Jun 30th, 2003
I am at a customer that just upgraded to Call Manager 3.3 from 3.1 This customer was doing direct transferes to v-mail using digit striping on the inbound calls into Unity. Call Manager 3.3 does this now, but in the "old days" in CM 3.1 we used a file on the Unity server to do this.
Does anyone remember the file name so that I can change delete this file and convert to the new scheme of using the Call Manager to do this?
Pete
lindborg Mon, 06/30/2003 - 07:43
  • Cisco Employee,
The files that end in .EXM are the extension remapping files - they can be named anything and you can have many of them for direct and forwarded calls - they should appear under \commserver\intlib\ExtensionMapping on your system. You can just rename them all to something with a different extension since at startup Unity looks in that directory for all files witha .EXM extension and attempts to load all the rules from them.
