Warning message
Port LB on 6500 CatOS
Jun 30th, 2003
How can I load balance two ports (not failover) on a 6509 with CatOS? I have them teamed on the server side. At the moment they do failover, but I would like to load balance them.
drhodes Mon, 06/30/2003 - 08:54
Many server folks I work with use the term Trunk to refer to what Cisco calls Port Channelling. If you can setup a trunk on your teamed-NICs and setup a port Channel on the corresponding switch ports. Note that the Port Channel must be setup on a single switch (multiple ports -- same switch). First attempt this in a test environment.
Command Example:
Prior to setting ports in a channel group make sure they exist in the same VLAN, and all other settings match (speed, duplex, other optional settings, ...)
set port channel 2/1-2 mode on
This assumes ports 2/1 and 2/2 are your teamed NICs switch ports
(( other options available))
