Warning message
mhoda Tue, 07/01/2003 - 09:42
  • Silver, 250 points or more
Yes, thats possible. You just need create the user profile on Radius server and then point all 6 routers to this same server. Here is the most basic form of config on the router -
aaa new-model
aaa authentication login default group radius local
radius-server host 10.1.1.1 key cisco
username cisco pass cisco --->This is needed for back door just incase if the Radius server is down.
Mynul
sagittarius Wed, 07/02/2003 - 08:06
I was able to successfully login to the router, but how can i configure to log in directly to enable prompt
Can i configure Privileges on RADIUS without ACS ?
ywadhavk Wed, 07/02/2003 - 08:40
  • Cisco Employee,
Hi Saggi,
Didn't really understood your part of the Q " RADIUS without ACS". Do you mean local configuration?
Here's some more info with config example.
aaa new-model
aaa authentication login default [group] local
aaa authorization exec default [group] local
Make sure to create the local user database as follows:
username abc privilege 0 password abc
username xyz privilege 1 password xyz
username special privilege 5 password special
username superuser privilege 15 password super
With the above setup, user abc can execute only disable, enable, exit, help, and logout commands.
User xyz can execute all the level 0 and level 1 commands.
User superuser can execute all the commands on the router.
On the router these are the 3 level of default commands:
-privilege level 0 — includes the disable, enable, exit, help, and logout commands
- privilege level 1 — normal level on Telnet; includes all user-level commands at the router> prompt
- privilege level 15 — includes all enable-level commands at the router#
prompt
Now based on your requirement, you can create a priv level bewteen 2-14 and assign any priv level 15 commands (level 0 and 1 would be inherited by default). Here is an example:
With this, user six is only able to execute all the level 0 & 1 commands. If the user need to execute "config t" on the router, he has to add the following line to add this level 15 commans to level 6.
privilege exec level 5 configure terminal
privilege exec level 5 gatekeeper
privilege exec level 5 write memory
thanks,
yatin
mhoda Wed, 07/02/2003 - 09:01
Yes, it is possible. All you need is the following line on the router -
aaa authorization exec default group radius
In IAS, you need to make sure that you assign priv-lvl to from 2 to 15 in your IAS server. That will take you to the privilege mode directly.
Mynul
