Warning message
Translation Pattern mapping DID to internal extension
Answered Question
Jul 1st, 2003
Carrier is sending 4 digits. I want DID 0760 to map to internal extension 7300. In the translation pattern do I put the internal ext. in the Called Party Transform Mask ?
Correct Answer by thusain about 14 years 1 month ago
You can make the translation on the gateway or the CCM. If you have an IOS gateway, you can make a translation rule and apply it to the outbound voip dial peer as such
translation-rule 1
rule 1 ^0760 7300
dial-peer voice 10 voip
translate-outgoing called 1
OR :
On the call manager alternatively you can make a translation patterna nd change the called party number from 0760 to 7300
Overall Rating: 5 (2 ratings)
Correct Answer
thusain Tue, 07/01/2003 - 15:21
  • Silver, 250 points or more
translation-rule 1
rule 1 ^0760 7300
OR :
