h323 vg200 gateway locks
Jul 3rd, 2003
I have a vg200 running 12.2(13b) h323 gateway services through a t-1 connected to a fujitzu PBX. Every so often the outbound traffic is halted and I receive a fastbusy. The circut will return to normal upon reload of the 200. I have checked the t-1 interface and it shows an up status plus when I do a "sh voice call sum" I'm not seeing any locked channels. I have read about the same type of problem on gateways running mgcp, but this is a 323.
Any help will be well received. I currently have to reload the 200 twice a day.
jtufail Thu, 07/03/2003 - 12:48
Can you please check the "show voice port status". I would like to see what state are they stuck. Also can you please send sh ver and what CCM version are you running. There have been some reported bug with port lock ups on vg200 with CCM as you have already seen.
tostrander Fri, 07/04/2003 - 07:29
We are running ccm 3.3 and the "sh voic port sum" is below
1/0:23 1 isdn-voice up down none none y
1/0:23 2 isdn-voice up down none none y
1/0:23 3 isdn-voice up down none none y
1/0:23 4 isdn-voice up down none none y
1/0:23 5 isdn-voice up down none none y
1/0:23 6 isdn-voice up down none none y
1/0:23 7 isdn-voice up down none none y
1/0:23 8 isdn-voice up dorm none none y
1/0:23 9 isdn-voice up dorm none none y
1/0:23 10 isdn-voice up dorm none none y
1/0:23 11 isdn-voice up dorm none none y
1/0:23 12 isdn-voice up dorm none none y
1/0:23 13 isdn-voice up dorm none none y
1/0:23 14 isdn-voice up down none none y
1/0:23 15 isdn-voice up down none none y
1/0:23 16 isdn-voice up down none none y
1/0:23 17 isdn-voice up down none none y
1/0:23 18 isdn-voice up down none none y
1/0:23 19 isdn-voice up down none none y
1/0:23 20 isdn-voice up down none none y
1/0:23 21 isdn-voice up down none none y
1/0:23 22 isdn-voice up down none none y
1/0:23 23 isdn-voice up dorm none none y
1/1:23 1 isdn-voice up down none none y
1/1:23 2 isdn-voice up down none none y
1/1:23 3 isdn-voice up down none none y
1/1:23 4 isdn-voice up down none none y
1/1:23 5 isdn-voice up down none none y
1/1:23 6 isdn-voice up down none none y
1/1:23 7 isdn-voice up down none none y
1/1:23 8 isdn-voice up down none none y
1/1:23 9 isdn-voice up down none none y
1/1:23 10 isdn-voice up down none none y
1/1:23 11 isdn-voice up down none none y
1/1:23 12 isdn-voice up down none none y
1/1:23 13 isdn-voice up down none none y
1/1:23 14 isdn-voice up down none none y
1/1:23 15 isdn-voice up down none none y
1/1:23 16 isdn-voice up down none none y
1/1:23 17 isdn-voice up down none none y
1/1:23 18 isdn-voice up down none none y
1/1:23 19 isdn-voice up down none none y
1/1:23 20 isdn-voice up down none none y
1/1:23 21 isdn-voice up down none none y
1/1:23 22 isdn-voice up down none none y
1/1:23 23 isdn-voice up down none none y
Thanks for the intrest and let me know if you need any other information.
