Warning message
EZVPN XAUTH
Jul 6th, 2003
I have configured a 1760 as an EVPN server with clients succesfully connecting using unified client version 4.x. now trying to configure it to connect to a PIX 501 running in Network extention mode. Having problems with extended authentication, using local username database as per cisco.com examples. Was working initially now does not want to know.
Anyone experienced this and any advice.
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization network vpnservertest local
aaa accounting exec default start-stop group tacacs+
aaa session-id common
ip subnet-zero
crypto isakmp client configuration group vpnservertest
dns x.x.x.x x.x.x.x
wins x.x.x.x x.x.x.x
domain idc.uk.parker.corp
pool serverpool1
ON PIX
vpnclient vpngroup vpnservertest password ********
vpnclient username x.x.x.x password ********
vpnclient server x.x.x.x
vpnclient mode network-extension-mode
vpnclient enable
drolemc Thu, 07/10/2003 - 07:10
  • Silver, 250 points or more
If you are using PIX OS v6.2(1), you are probably runing into bug CSCdx53187. The PIX in NEM mode, configured as an EZVPN client, has problems negotiating the IPSec SA. Upgrade to a newer version would be a good idea.
