Can anyone look at my output and tell me why my Terminal Server not serving
Answered Question
Jul 7th, 2003
I'm wondering if its because I don't have enough mem. but not for sure
#show ver
IOS (tm) 2500 Software (C2500-D-L), Version 12.0(5)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Fri 23-Jul-99 03:53 by kpma
Image text-base: 0x03043078, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFT
WARE (fc1)
HQ_Qu_TS uptime is 55 minutes
System image file is "flash:c2500-d-l.120-5.T.bin"
cisco 2509 (68030) processor (revision M) with 2048K/2048K bytes of memory.
Processor board ID 09298124, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8 terminal line(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
HQ_Qu_TS#show run a telnet connect
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname HQ_Qu_TS
ip subnet-zero
ip host Bronx_SW1 2005 5.5.5.5
ip host Frame_FS1 2004 4.4.4.4
ip host Brooklyn_R1 2003 3.3.3.3
ip host Bronx_R1 2002 2.2.2.2
!process-max-time 200
interface Loopback0
ip address 1.1.1.1 255.255.255.255
no ip directed-broadcast
interface Ethernet0
ip address 192.168.10.1 255.255.255.0
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
ip classless
no ip http server
line con 0
transport input none
line 1 8
no exec
transport input all
line aux 0
line vty 0 4
login
end
Q_Qu_TS#telnet 2.2.2.2 2002
Trying 2.2.2.2, 2002 ...
% Destination unreachable; gateway or host down
HQ_Qu_TS#telnet 3.3.3.3 2003
Trying 3.3.3.3, 2003 ...
HQ_Qu_TS#
Correct Answer by deilert about 14 years 1 month ago
enter this
ip host Bronx_R1 1.1.1.1 2002
Correct Answer by frejac about 14 years 1 month ago
The ip-address that you should enter is the loopback of the terminal server. not the target router.
(Meaning that you should use 1.1.1.1)
Overall Rating: 5 (2 ratings)
frejac Mon, 07/07/2003 - 08:58
1st: where are the ip-adresses 2.2.2.2 and 3.3.3.3? Didnt you mean to point them to 1.1.1.1?
2nd: do a show line and see what it says regarding speed and bits. I suppose the "no exec" may do something negative for you, but I dont remember right now.
a.ford Mon, 07/07/2003 - 09:19
The ip addresses are the loopbacks of the other routers (2x-2503, 1x4500)
the no exec keeps the system from spawning an exec process which ocupys the line making it inaccessible.
HQ_Qu_TS#show line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 0 0 0/0 -
1 TTY 9600/9600 - - - - - 0 0 0/0 -
2 TTY 9600/9600 - - - - - 0 9 0/0 -
3 TTY 9600/9600 - - - - - 0 0 0/0 -
4 TTY 9600/9600 - - - - - 0 0 0/0 -
5 TTY 9600/9600 - - - - - 0 0 0/0 -
6 TTY 9600/9600 - - - - - 0 0 0/0 -
7 TTY 9600/9600 - - - - - 0 0 0/0 -
8 TTY 9600/9600 - - - - - 0 0 0/0 -
9 AUX 9600/9600 - - - - - 0 0 0/0 -
10 VTY - - - - - 0 0 0/0 -
11 VTY - - - - - 0 0 0/0 -
12 VTY - - - - - 0 0 0/0 -
13 VTY - - - - - 0 0 0/0 -
14 VTY - - - - - 0 0 0/0 -
deilert Mon, 07/07/2003 - 09:36
  • Silver, 250 points or more
you do not need the ip addresses of the loopbacks in your ip host statement . just the async line that is connected to that box .
i.e.ip host Bronx_SW1 1.1.1.1 2005
you can also add menu statements
ip host myport x.x.x.x (loopback address of router )
menu tty title ^C
Type a number to select a device
^C
menu tty text 1 connection to router 1
menu tty command 1 telnet myport 2001
menu tty text 2 connection to router 2
menu tty command 2 telnet myport 2002
menu tty text 10 EXIT the menu
menu tty command 10 menu-exit
menu tty clear-screen
a.ford Mon, 07/07/2003 - 10:09
It won't allow me to just enter the line number (see below)
HQ_Qu_TS#config t
HQ_Qu_TS(config)#no ip host Bronx_R1 2002 2.2.2.2
HQ_Qu_TS(config)#ip host Bronx_R1 2002
% Incomplete command.
HQ_Qu_TS(config)#
Correct Answer
frejac Mon, 07/07/2003 - 10:12
a.ford Mon, 07/07/2003 - 10:21
Dayum, ol doppie me. it worked. I had a 2509 a few years ago, and could've sworn I did it like with the loopback of the other router. \
Thanks folks.
Correct Answer
deilert Mon, 07/07/2003 - 10:15
enter this
