command "copy run start" or "write mem" with snmp ?
Jul 7th, 2003
It is possible on Switches or Routers supporting "copy run start" or "write mem" to set this command through an snmp set ?
Does anyone know the mib-values ?
Normally I use Netconfig in CW2000 for this. But I thought of an alternative way with snmp.
Thank you.
jhathcock Mon, 07/14/2003 - 13:18
If you look in the lsystem branch of the Cisco MIB you will find the MIB instances that do this. The instance is in the 50s if I remember correctly. If you have Unix or Linux around, you can write a script that can push or pull configs fairly easily if you have the command line snmp tools on your box. I was able to write a dirty one in about an hour and use it as a backup in case CW2k goes belly up.
