connection between isp and my exchange
Jul 8th, 2003
from my exchange i can telnet to isp server on port 25 bt not from ISP.i have firewall in between when i am pinging my public ip it is showing the following on my router which is on outside world on public IP's.other exchange servers are running fine
Sending 5, 100-byte ICMP Echos to 212.116.203.5, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
rais Wed, 07/09/2003 - 07:47
  • Silver, 250 points or more
To enable access to your Exchange/SMTP gateway, just open up port 25 on your firewall. In Cisco's PIX, this is done using 'static' command.
Looks like your ICMPs are disabled as well, which I dont think is a default feature of PIX.
Thanks.
