E1 bandwidth
Jul 9th, 2003
Can Router 3640-IOS 12.0(7) support E1 bandwidth? When we connect E1 bandwidth by two 2500 or 2600, they are working fine but when we connect 3640 to either 2500 or 2600, it fails.
Please help!
deilert Wed, 07/09/2003 - 03:18
  • Silver, 250 points or more
What kind of card is in the 3640 ? Can tou paste in a sh interface serial x and a sh version
chukuo Wed, 07/09/2003 - 18:32
Below is our "tested 3640 router" info.
1. WIC 2T card
2. sh int
Serial0/1 is up, line protocol is down
Hardware is DSCC4 Serial
Internet address is 192.168.10.2/24
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Listen
Closed: IPCP, CDPCP
Last input 00:04:58, output 00:00:18, output hang never
Last clearing of "show interface" counters 22:11:38
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
10745 packets input, 150430 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
6 input errors, 3 CRC, 2 frame, 0 overrun, 0 ignored, 1 abort
35791 packets output, 501074 bytes, 0 underruns
0 output errors, 0 collisions, 4081 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
3. sh version
IOS (tm) 3600 Software (C3640-I-M), Version 12.0(7)XK1, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 16-Mar-00 22:09 by phanguye
Image text-base: 0x600088F0, data-base: 0x608C2000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
ROM: 3600 Software (C3640-I-M), Version 12.0(7)XK1, EARLY DEPLOYMENT RELEASE SOF
TWARE (fc1)
Router uptime is 22 hours, 4 minutes
System image file is "flash:c3640-i-mz.120-7.XK1"
cisco 3640 (R4700) processor (revision 0x00) with 27648K/5120K bytes of memory.
Processor board ID 26604484
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
chukuo Sun, 07/13/2003 - 23:50
I upgrade IOS to 12.1(1)T suggested by the link but we still can not make it work. We found out when we connect to E1 by WIC 1T card and IOS 12.0(7) version, connection is up!
