Warning message
IEV Lists Source and Destination Addresses Wrong
Jul 10th, 2003
Cisco IEV v4.0(1)S37
Cisco IDS v4.0(2)S47
Cisco PIX v6.2(2)
A "TCP Upper Port Sweep" popped up on IEV today showing our webserver as the Source Address. After checking the PIX log, I find that IEV has the wrong source and destination addresses listed.
According to the PIX syslog, our webserver was the destination address. Here is a sample of the log:
WTsyslog[2003-07-10 11:48:40 ip=x.x.x.x pri=6] <190>Jul 10 2003 11:48:40: %PIX-6-302013: Built inbound TCP connection 6855503 for outside:12.16.16.118/42620 (12.16.16.118/42620) to dmz1:192.168.1.2/443 (x.x.x.x/443)
WTsyslog[2003-07-10 11:48:42 ip=x.x.x.x pri=6] <190>Jul 10 2003 11:48:42: %PIX-6-302013: Built inbound TCP connection 6855504
for outside:12.16.16.118/42621 (12.16.16.118/42621) to dmz1:192.168.1.2/443 (x.x.x.x/443)
Yet the IEV lists 12.16.16.118 as the Destination Address. This kind of traffic goes on for awhile, with the source incrementing the ports upward.
The log also shows 12 other hosts connected with our webserver in this fashion over a 1 hour period. IEV has the Source and Destination addresses reversed on these as well. (if one can believe the PIX log)
Am I missing something?
Is there something that needs to be addressed in IEV or the IDS?
Tony
Overall Rating: 5 (1 ratings)
jlin1 Thu, 07/10/2003 - 12:53
Tony,
First, you can check if this is IDS or IEV problem by logging into sensor CLI and issue "show events" command. When this kind of traffic comes, the sensor CLI will show the corresponding events which include the attack (source) and victim (destination) ip addresses. If IEV display the same information as shown on sensor CLI, then it is IDS problem. Otherwise, it could be IEV problem.
Second, the IEV signature need to be updated to latest S47. S37 is quite old, but it should not have impact on the reversed src/dest addresses problem. You can download IEV signature update from CCO too.
Let us know how it goes.
Jie
tscislaw_2 Fri, 07/11/2003 - 07:11
Jie,
Here's what I found on the IDS event log:
signature: sigId=3010 sigName=TCP Upper Port Sweep subSigId=0 version=S37
participants:
attack:
attacker:
addr: locality=OUT x.x.x.x (our webserver address)
port: 443
victim:
addr: locality=OUT 12.16.16.118
port: 42620
port: 42621
port: 42622
port: 42623
port: 42632
port: 42635
port: 42639
port: 42638
port: 42641
port: 42640
port: 42644
port: 42645
port: 42646
port: 42648
port: 42649
port: 42651
port: 42653
port: 42654
port: 42655
port: 42657
port: 42658
port: 42659
port: 42660
port: 42661
port: 42662
So, if I read that right, the IDS is saying our webserver is the "attacker". Contrary to what the PIX log shows.
Now, there are other entries of this same signature with correct attacker/victim addresses. But, these are not to our webserver (which is on a PIX DMZ) but to NAT'd addresses for our internal network hosts.
Suggestions?
Tony
mcerha Fri, 07/11/2003 - 08:30
  • Bronze, 100 points or more
From all indications, the source / destination addresses are probably correct in the alarm. This looks like a probable false postive alarm. The "victim" in this case is probably using Internet Explorer to browse the "attacker" web server. To improve performance, IE uses Resets to terminate TCP connections instead of the normal graceful disconnect. Because web browsers typically make many connections to a web server, it looks to the IDS like the web client is sending many Reset packets to the web server in response to a port scan. Signature 3010 is a little different than other port scan signatures in that is looks for lots of Resets going from host A to host B. If seen, the IDS will report B as the actual attacker by flipping the source and destination addresses in the alarm. Further validation of this false positive could be made by looking at the logs of the web server for the client type. A note in the NSDB will be made to reflect this condition as a possible false positive.
tscislaw_2 Mon, 07/14/2003 - 07:03
Sounds good to me.
Thanks for the detailed explaination.
Tony
