2 vpn group for different purpose in Pix Firewall
ccsam
I'm trying to configure 2 group of user who will access different servers in different segment. Anyone have any idea or implement before? I try to search for the documentation but could not find any? Appreatiate your help and thanks in advance.
regards,
Sam
gfullage
Just create two set's of "vpngroup" commands using different group names. Assign each of these different groups a different IP address pool within the PIX. Then you can set up access-lists on your internal network to only allow each pool of addresses access to certain internal hosts.
Similarly, you could assign each group a specific split-tunnel network list, and only allow each group access to certain internal hosts that way.
and what about the
isakmp client configuration address-pool local dealer outside
one can only add one pool, so what is this for ?
thanks uli
gfullage
You don't need this command if you're using the VPN Client. Just do the following to assign two different IP pools:
vpngroup group1 address-pool ippool1
vpngroup group2 address-pool ippool2
ip local pool ippool1 10.1.1.1-10.1.1.254
ip local pool ippool2 10.2.2.1-10.2.2.254
