Warning message
PAT question
Jul 11th, 2003
hi,
I am trying to use PAT over dial-up users in async interfaces.( one valid IP for 30 dial-up users) i applied following commands , but it can't work !
plz someone help me what's wrong in my configuration?
when i use show ip nat translation..it didn't show me..and dial-up users can't get connected.
thanks in advanced,
mojga
version 12.2
int ethernet 0
description connect to internet
ip address 192.168.19.2 255.255.255.0
ip nat outside
interface FastEthernet0
description to LAN connection
ip address 62.145.52.131 255.255.255.128
ip policy route-map uplink
duplex auto
speed auto
no cdp enable
interface Group-Async4
description dial-up E1 line-group4
ip unnumbered Ethernet0
ip nat inside
encapsulation ppp
ip tcp header-compression
no ip mroute-cache
ip policy route-map RMAP
async mode interactive
ppp authentication pap chap cis
ppp authorization cis
ppp accounting cis
group-range 91 120
ip nat pool sh_nat 62.145.52.132 62.145.52.132 prefix-length 24
ip nat inside source list source_nat pool sh_nat overload
ip access-list extended source_nat
permit ip 192.168.11.0 0.0.0.31 any
ip route 0.0.0.0 0.0.0.0 192.168.19.10
oj88 Fri, 07/11/2003 - 21:40
You will have to redo your NAT config as well as verify your interfaces.
Based on your config, it seems that you have connected the interface with the valid IP address (62.145.52.131) to your LAN and the private IP address (192.168.19.2) to your ISP.
Also, you have put the IP NAT OUTSIDE command on your LAN and IP NAT INSIDE to your ISP. Also, use private addresses when defining the NAT pool.
mojganmasroor Fri, 07/11/2003 - 22:45
as i told before our isp connected to internet thru wireless router and interface ethernet0 is our WAN link. ( private ip address for e0 is correct and with this configuration we have internet connection don't be worry)
meanwhile, i putted IP NAT OUTSIDE in fastethernet0 too, but it didn't get answer.
i wanted only set PAT for dial-up users. plz suppose you want write this senario, plz send your config commands for me.
thanks in advanced,
mojga
