Warning message
any body know this error??
Jul 16th, 2003
Initializing C2900XL flash...
flashfs[1]: 18 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 3272704
flashfs[1]: Bytes available: 339968
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
...done Initializing C2900XL flash.
C2900XL POST: System Board Test: Passed
C2900XL POST: Daughter Card Test: Passed
C2900XL POST: CPU Buffer Test: Passed
C2900XL POST: CPU Notify RAM Test: Passed
C2900XL POST: CPU Interface Test: Passed
C2900XL POST: Testing Switch Core: Passed
C2900XL POST: Testing Buffer Table: Passed
C2900XL POST FAILURE: sp_post_data_buffer: The received frame doesn't match the sent-out frame.
C2900XL POST FAILURE: Address: 0x003FFDC0
C2900XL POST FAILURE: Send bytes : 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0800
C2900XL POST FAILURE: Receive bytes: 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
C2900XL POST FAILURE: Address: 0x003FFDE0
C2900XL POST FAILURE: Send bytes : 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0200
C2900XL POST FAILURE: Data Buffer Test: Failed
C2900XL POST FAILURE: Configuring Switch Parameters: Failed
C2900XL POST FAILURE: Switch Core failure on data buffer POST
C2900XL POST FAILURE: Cannot test Modules due to failure of Switch Core POST
Del Mar Failure (0th Del Mar): req system failed to init
C2900XL POST FAILURE: ATM: required system failed to init
C2900XL POST: Ethernet Controller Test: Passed
C2900XL POST FAILURE: MII Test: Failed
C2900XL POST FAILURE: Error waiting for Ethernet Controller and SW_PARAMS
C2900XL POST FAILURE: Initialization/POST failed
C2900XL POST FAILURE: AT: Failing because system POST failed
Exception (8192)! Debug Exception (Could be NULL pointer dereference)
CPU Register Context:
Vector = 0x00002000 PC = 0x000F01F8 MSR = 0x00029200 CR = 0x22000024
LR = 0x000F344C CTR = 0x001D9790 XER = 0x20000000
R0 = 0x00000000 R1 = 0x004B71C8 R2 = 0x00000000 R3 = 0x00000000
R4 = 0x00000001 R5 = 0x00000000 R6 = 0x004B7360 R7 = 0x004B7360
R8 = 0x00000008 R9 = 0x00000000 R10 = 0x0000FFFF R11 = 0x00450000
R12 = 0x42000024 R13 = 0x00000000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000020 R26 = 0x004B7360 R27 = 0x004B7360
R28 = 0x00000020 R29 = 0x00002513 R30 = 0x00000001 R31 = 0x00000000
Stack trace:
PC = 0x000F01F8, SP = 0x004B71C8
Frame 00: SP = 0x004B71E8 PC = 0x40000016
Frame 01: SP = 0x004B7260 PC = 0x000F344C
Frame 02: SP = 0x004B72F0 PC = 0x000F4140
Frame 03: SP = 0x004B7310 PC = 0x000E4BB4
Frame 04: SP = 0x004B7338 PC = 0x001F01B8
Frame 05: SP = 0x004B7358 PC = 0x001F02B4
Frame 06: SP = 0x004B7390 PC = 0x00238C6C
Frame 07: SP = 0x004B7398 PC = 0x00237E68
Frame 08: SP = 0x004B7410 PC = 0x002380B4
Frame 09: SP = 0x004B7428 PC = 0x00286C7C
Frame 10: SP = 0x004B7430 PC = 0x001DEC1C
Frame 11: SP = 0x004B7450 PC = 0x001DECCC
Frame 12: SP = 0x004B7468 PC = 0x001498D0
Frame 13: SP = 0x004B7510 PC = 0x00149A4C
Frame 14: SP = 0x00000000 PC = 0x001E6830
thanks
kin
kkalaycioglu Wed, 07/16/2003 - 00:27
  • Bronze, 100 points or more
It seems that POST (power-on self test)procedure fails on some stages beginning with data buffer test and some others (sw core etc. because of data buffer test fail). Is this a new equipment? Did this situation happen after a software upgrade ?
kpahare Wed, 07/16/2003 - 21:46
Yes it is a new switch. but i'm encountering same problem in plenty of switches. (all of them 2900 Series with module 2922-xl-v). I've checked the broadcast in trunk port which shows "Received 17954674 broadcasts", in a period of 3 days!! Is this normal? Are these switches pirated!!?
thanx
kin
