Warning message
Configuring NAT on a 2600 series Router
Jul 16th, 2003
Can some one tell me how NAT works. I have the following problem:
I have one IP address and one 2600 series router. I have setup an internal Lan with three hosts.
I have configured my N/W with the following:
1) Assigned FastEthernet 0/0 with the IP address available (Say 213.190.60.13) & this port is connected to my ISP' via a ethernet cable.
2) Assigned 192.168.100.1 to the FastEthernet 0/1 and this port is connected to my local Lan with three hosts(192.168.100.2,192.168.100.3,192.168.100.4) using a Hub.
My N/W works fine. I want that whenever a request to my assigned IP (213.190.60.13) comes from outside it should be forwarded to my internal LAN host 192.168.100.3.
A quick help in this regard will be highly appreciated.
Jaswant
edmonds_robert Wed, 07/16/2003 - 07:03
The following is an example of how you may need to set it up.
interface FastEthernet 0
description Outside Interface
ip address 213.190.60.13 255.255.255.252
ip nat outside
interface Ethernet1
description Inside Interface
ip address 192.168.100.1 255.255.255.0
ip nat inside
ip nat inside source static 192.168.100.3 213.190.60.13
!YOU MAY OR MAY NOT NEED THE NEXT LINE, DEPENDING ON YOUR SETUP
ip route 213.190.60.13 255.255.255.255 FastEthernet1
