Warning message
Multilink PPP on 2 T-1 lines
Answered Question
I have a 3640 at site1 and will have a 3725 at site2. We now have 1 FULL T-1 but are getting a second FULL T-1 . I have found several articles on configuring multilink PPP but none specifically written for configuring 2 T-1 lines. The intent is increase WAN bandwidth and load balancing. Suggestions please.
Al
Correct Answer by sachinraja about 14 years 1 month ago
You need to map the two T1 links onto a multi-link group and assign that group to the multilink interface. Multilink T1 links can automatically do load balancing.
All Ip addresses and routes should be given towards the multilink interfaces and not the physical interfaces.
Sample config :
interface multilink1
ip address 1.1.1.1 255.255.255.252
encapsulation ppp
ppp multilink
multilink-group 5
int ser 0/0
no ip address
encapsulation ppp
ppp multilink
multilink-group 5
interface serial0/1
no ip address
encapsulation ppp
ppp multilink
Overall Rating: 5 (1 ratings)
bbuhlman Mon, 07/21/2003 - 11:35
I am using 2 T-1' between routers also and I only turned on CEF with no options and it has done the load balancing for me. It's really simple. Check this out too. Put on the serial ints ip load sharing per packet. See below for part of my config:
Bill
ip cef
no ip finger
interface FastEthernet0/0
ip address 10.19.3.2 255.255.255.0
no ip mroute-cache
speed 100
full-duplex
interface Serial0/0
bandwidth 1544
ip unnumbered FastEthernet0/0
ip load-sharing per-packet
encapsulation ppp
no fair-queue
interface Serial0/1
bandwidth 1544
encapsulation ppp
router eigrp XXX
network 10.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route XXXXXXXXXXXXXXXXXXXX
no ip http server
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps envmon
line con 0
exec-timeout 0 0
transport input none
line aux 0
line vty 0 4
password 7
login
ntp clock-period 17208436
Correct Answer
sachinraja Tue, 07/22/2003 - 06:45
  • Red, 2250 points or more
Sample config :
encapsulation ppp
ppp multilink
multilink-group 5
int ser 0/0
no ip address
encapsulation ppp
ppp multilink
multilink-group 5
interface serial0/1
no ip address
encapsulation ppp
ppp multilink
