Warning message
Corporate Directory Error.
Jul 21st, 2003
Call Manager 3.3(2)spB. When I try to search the corporate directory I get the following "An error occurred and was logged. (undefined)"
This issue has only started recently, and rebooting the call managers (then a few phones) didn't seem to solve it.
Anybody have any suggestions?
chris.schuerger... Mon, 07/21/2003 - 12:24
Dug a little deeper on this issue, and I've found what might the problem.
If I open CCMAdmin and go to 'Users' I get a page cannot be displayed type error page in the frame where I should be seeing the users. When I open DC Directory, I see a directory in the right hand window called cisco.com, but when I try to bring up its properties, I get message that tells me the properties are not available because the entry no longer exists, then it disapears off of the screen. If I close DC Directory and reopen it, the cisco.com directory is again listed, but I get the same error when I try to touch it.
Anybody have a clue what could have caused this?
ftsao49 Tue, 07/22/2003 - 11:14
I had an issue similar to this, and found out that my DC directory was corrupted. I had some success pointing the corporate directory to my publisher, and subsequently copied the directory structure where the DC directory was contained from the publisher to the subscriber.
chris.schuerger... Wed, 07/23/2003 - 11:47
My DC Directory Manager issue that I talked about above was because I was using the wrong password, so that is non-issue at this point, when I use the correct password, it looks as though my directory is populated and happy.
So let me take a step back and re-state my issue and its symptoms.
The corporate directory search feature on the phones returns an error. The same search from a PC also returns an error. If I open ccmAdmin, and try to view the global users list, I get a Page could not be found error page with a 500--Internal server error designation.
While this issue has been going on, I have been able to create new phones, and make chages to phones, so it would seem logical that my DC Directory is functioning at some level.
What would be the best way to attack this issue?
gary-allen Wed, 07/23/2003 - 12:59
Check the LMHost file. Make sure your CCMs are defined.
ftsao49 Wed, 07/30/2003 - 13:42
Chris,
Does your Call Manager name contain an underscore?
chris.schuerger... Wed, 07/30/2003 - 14:31
Nope, but I did find and fix the error (with the help of the fine folks at Cisco TAC)
In this registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\Directory Configuration
there were two entries set as follows:
CISCOBASE REG_SZ o=
MGRDN REG_SZ cn=Directory Manager, o=
we changed them to this:
CISCOBASE REG_SZ o=cisco.com
MGRDN REG_SZ cn=Directory Manager, o=cisco.com
did a restart on the IIS Admin service and everything was working properly
