LINE_REPLY error
kevin8941
I have a tapi code. After successfully linedrop, lineDeallocateCall, lineclose, lineshutdown, the next time when I place a call, sometimes I receive LINE_REPLY error message, the param2 shows LINEERR_RESOURCEUNAVAIL, but this is not always happen. But once it happens, I have to try 2-7 times to make a call again. I wait for the LINE_REPLY message after I call linedrop method. Does anybody knows what is missing?
jshepard
Level 4
Level 4
This sounds like a problem you could use Cisco Developer Services to assist you with.
www.cisco.com/go/developersupport
Using logs, and call flow, they will be able to diagnose and troubleshoot.
I downloaded the TAPISampleApp example from cisco :
This sample applications exemplifies the following TAPI functionalities:
a. Answering a call
b. Playing a greeting
c. User Options
1. Recording a message
2. Call Redirecting
3. Call Forwarding
4. Call Conferencing
5. End Recording Message
d. Silence detection."
When I launch this application, I receive :
Device found!!
Device ID: 10
Device Name: Cisco Line: [CTI-01] (8045)
Error in opening line.
So I have also a lineerr_resourceunavail ...
Do you know what can be the problem ?
Thierry
