How to Activate or Config Router so I can telnet into it
thisisshanky Tue, 07/22/2003 - 16:24
Configuration no 1 : If you use this, you wont be prompted for a password while you telnet. Still you will need an enable password to get into enable mode.
enable password cisco
line vty 0 4
no login
Configuration no 2: This is a more standard type of configuration. You will need to input a telnet password as well as an enable password.
line vty 0 4
login
password cisco
Hope that helps.
hbaerten Wed, 07/23/2003 - 05:37
and for the sake of completeness (well, without considering Radius or Tacacs authentication :))
configuration no 3:
username xxxxxxxxxx password xxxxxxxxxxx
[etc]
enable password xxxxxxxxxxx
line vty 0 4
login local
This will allow you to login with a username and password (which is specific to that user).
The enable password is still unique though.
You can also implement this for the console interface, btw, just replace "line vty 0 4" with "line con 0".
hth
Herbert
