radius & switch
Jul 22nd, 2003
I set a switch to use radius server. And I left a backdoor for local. The command as :
set authentication login local enable
set authentication radius enable telnet
But when the radius down, switch still show user/password.When I put username(whatever)/password(login), it failed.
Why?
mhoda Thu, 07/24/2003 - 14:21
  • Silver, 250 points or more
What version of code you are running? Please make sure to run 7.5.1 or above for the local user database authentication. Here is the link that explains the details -
http://www.cisco.com/en/US/tech/tk583/tk642/technologies_tech_note09186a0080094ea4.shtml#c
In the link, it shows how to create the local user. Please make sure to do this step. Regards,
Mynul
changh Thu, 07/24/2003 - 18:13
Yes, I have checked the article. But in the STEP B, it configure radius used local as a backdoor, which catos is from 5.1 to 7.5.1.
I just wander how it works at catos before 7.5.1
