Why I can't get ciscoMemoryPoolUtilization1Min?
Jul 22nd, 2003
$ snmpget -c public -v1 10.1.200.2 1.3.6.1.4.1.9.9.48.1.2.1.1.0
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: SNMPv2-SMI::enterprises.9.9.48.1.2.1.1.0
$ snmpget -c public -v1 10.1.200.2 1.3.6.1.4.1.9.9.48.1.1.1.6.0
SNMPv2-SMI::enterprises.9.9.48.1.1.1.6.1 = Gauge32: 16313376
the router's ios is c3660-js-mz.122-5d.bin.
Why I can't get ciscoMemoryPoolUtilization1Min ? From SNMP Object Navigator ,I know the ios support ciscoMemoryPoolMIB .Do I need any another config or something ?
thanks for your help
Henry
rmushtaq Wed, 07/23/2003 - 08:45
  • Blue, 1500 points or more
Tyr using snmpwalk instead. For doing a get you have to make sure that you're using the correct index first.
henrybb Wed, 07/23/2003 - 22:54
The oid which used with snmpget is get from cisco . I am sure it is correct. Maybe it can't get success because other reason.
thanks
Henry
jolmo Thu, 07/24/2003 - 04:26
  • Silver, 250 points or more
Maybe I'm wrong, but after seeing that error messages, I think the problem is you are trying to access an object that is in CISCO-MEMORY-POOL-MIB, BUT this object is imported from SNMPv2_SMI-MIB which is not supported by your IOS version.
