Vlans in 2924
Jul 23rd, 2003
My Config on 2924 switch is like this.
int vlan 4
ip address 192.168.10.1 255.255.255.0
no shut
int vlan 5
ip address 192.168.20.1 255.255.255.0
no shut
int fa0/1
switchport access vlan 4
int fa0/2
switchport access vlan 5
I have servers connected to fa0/1 and fa0/2 having IP 192.168.10.2 and 192.168.20.2 respectively.
Vlan 4 is up and working fine. I am able to telnet into switch with IP 192.168.10.1 Now when I shut vlan 4 and bring up vlan 5 , it comes up, but I m not able to telnet using vlan 5 IP.
Is there a routing problem here?
deilert Wed, 07/23/2003 - 09:33
  • Silver, 250 points or more
your default gateway is mostlikely in vlan 4 , you can try to add another default route that connects to vlan 5
prafuljaded Wed, 07/23/2003 - 09:48
Thanx for the replies.
I m able to telnet into the switch with vlan 4 as admin no shut. But when I shut vlan 4 and bring up vlan 5 it comes up , vlan 4 goes down , but I m not able to telnet into switch as before.
Thanx in advance
