Warning message
VPN Client - 3660 IOS 12.2
Jul 23rd, 2003
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
I'm trying to set up VPN Client access for traveling users into our network through a 3660 router running IOS 12.2 (16a). This is the specific image: c3660-jk9o3s-mz.122-16a
I've tried more setups than I care to think of and nothing is working. I get this error every time: "Secure VPN Connection terminated locally by the client. Reason: The remote peer is no longer responding."
I've never setup VPN Client before and about the only thing I can find on the site are a few hundred docs showing how to set up the Client with a RADIUS or TACACS server and VPN Concentrator 3000 series. I haven't found anything useful in the VPN Client setup documentation either (HTML stuff on the site), so I figured I'd turn here.
Anyway here is my current config on the router...if you see anything wrong please let me know.
logging queue-limit 100
logging rate-limit 1000
aaa new-model
aaa authentication login userauthen enable
aaa authentication login userauthen local
aaa authorization network userauthor local
enable password 7 xxxxxxxxxxxxxxxxxxxxx
username all
username ** privilege 15 password 7 xxxxxxxxxxx
username ** privilege 0 password 7 xxxxxxxxxxx
ip subnet-zero
no ip source-route
ip icmp rate-limit unreachable 5000
ip domain-list xxxxxxxxxxxxxx.com
ip domain-name xxxxxxxxxxxxxx.com
ip name-server 12.127.16.68
ip name-server 172.0.0.10
ip inspect audit-trail
ip inspect max-incomplete low 300
ip inspect max-incomplete high 400
ip inspect one-minute high 2000
ip inspect one-minute low 1800
ip inspect udp idle-time 600
ip inspect dns-timeout 10
ip inspect tcp idle-time 600
ip inspect name inbound udp alert on timeout 600
ip inspect name inbound realaudio timeout 600
ip inspect name inbound tcp alert on timeout 600
ip inspect name inbound ftp timeout 600
ip inspect name inbound http timeout 600
ip inspect name inbound rcmd timeout 600
ip inspect name inbound rtsp timeout 600
ip inspect name inbound tftp timeout 600
ip inspect name inbound netshow timeout 600
ip inspect name inbound streamworks timeout 600
ip inspect name inbound vdolive timeout 600
ip inspect name inbound cuseeme timeout 600
ip inspect name inbound h323 timeout 600
ip audit notify log
ip audit po max-events 100
ip dhcp-server 172.0.0.10
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp key * address xxx.xx.xxx.231
crypto isakmp key * address xxx.xx.xxx.130
crypto isakmp key * address xxx.xx.xxx.76
crypto isakmp key * address xxx.xx.xxx.89
crypto isakmp key * address xxx.xx.xxx.26
crypto isakmp key * address xxx.xx.xxx.24
crypto isakmp key * address xxx.xx.xxx.43
crypto isakmp key * address xxx.xx.xxx.217
crypto isakmp key * address xxx.xx.xxx.109
crypto isakmp key * address xxx.xx.xxx.106
crypto isakmp key * address xxx.xx.xxx.193
crypto isakmp key * address xxx.xx.xxx5.187
crypto isakmp client configuration address-pool local testpool
crypto ipsec transform-set cm-transformset-1 esp-3des esp-sha-hmac
crypto ipsec transform-set cm-transformset-2 esp-3des esp-sha-hmac
crypto dynamic-map testdynamicmap 1
set security-association lifetime seconds 68000
set transform-set cm-transformset-1
crypto map cm-cryptomap client authentication list userauthen
crypto map cm-cryptomap isakmp authorization list userauthor
crypto map cm-cryptomap client configuration address respond
crypto map cm-cryptomap 98 ipsec-isakmp dynamic testdynamicmap
call rsvp-sync
fax interface-type fax-mail
mta receive maximum-recipients 0
interface FastEthernet0/0
description connected to Outside_LAN
ip address xxx.xx.xxx.1 255.255.255.128
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description connected to Inside_LAN
ip address 172.0.0.1 255.255.255.128
ip nat inside
duplex auto
speed auto
interface FastEthernet1/0
description connected to xxxxxxxxxxxxxxx
ip address 192.168.250.1 255.255.0.0
ip nat inside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
interface Serial1/0
description connected to Internet
ip address xxx.xx.xxx.* 255.255.255.*
ip access-group 2000 in
ip access-group 2001 out
ip nat outside
ip inspect inbound out
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
router rip
version 2
network 10.0.0.0
network xx.0.0.0
network 172.0.0.0
network 192.0.0.0
ip local pool testpool 172.0.0.230 172.0.0.245
ip nat inside source route-map nonat interface Serial1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1/0
ip http server
logging facility syslog
logging 172.0.0.70
***Cut out most of ACL 2000 to save space***
access-list 2000 permit icmp any any echo
access-list 2000 permit icmp any any echo-reply
access-list 2000 permit icmp any any host-redirect
access-list 2000 permit icmp any any host-unknown
access-list 2000 permit icmp any any host-unreachable
access-list 2000 permit icmp any any packet-too-big
access-list 2000 permit icmp any any redirect
access-list 2000 permit icmp any any traceroute
access-list 2000 permit icmp any any unreachable
access-list 2000 permit icmp any any time-exceeded
access-list 2000 permit icmp any any administratively-prohibited
access-list 2000 permit esp any any
access-list 2000 permit udp any any eq isakmp
access-list 2000 deny ip 172.0.0.0 0.0.0.127 172.0.0.0 0.0.0.127
access-list 2000 deny ip host 255.255.255.255 any
access-list 2000 deny tcp any 172.0.0.0 0.0.0.127
access-list 2000 deny udp any 172.0.0.0 0.0.0.127
access-list 2000 deny ip any 172.0.0.0 0.0.0.127
access-list 2001 permit ip any any
access-list 2001 permit tcp any any
access-list 2001 permit udp any any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 199
snmp-server community xxxxxxxxxxxxxx
snmp-server enable traps tty
dial-peer cor custom
banner incoming ^C On^C
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
end
owillins Tue, 07/29/2003 - 11:44
  • Silver, 250 points or more
On which platform are you running the VPN client? Some issues like this one have been seen over Windows ME and old Client versions. Please ensure that you are using the latest version of the VPN client. Also check the key and make sure that you are using the right key. This should resolve the issue.
