Warning message
Phone trigger on event
Jul 25th, 2003
  • Cisco Employee,
I have an application for everytime a person gets a phone call in, or places a phone call I need some sort of trigger to be executed.. ie: drop a integer into a database or hit a webpage of some sort.
Main reason for this is we need to have a Outlook Journal Window Pop-up for the first phase of this project everytime a I/O call is made from a series of phones.
Thanks in advance
aaronw.ca Fri, 07/25/2003 - 12:40
  • Silver, 250 points or more
Sounds like a JTAPI/TAPI application... monitor the device and when a new call is detected perform some action. This has been discussed in a few threads here, and you'll want to pick up Cisco's JTAPI/TAPI spec from Cisco Developer Services (http://www.cisco.com/go/developersupport )if you don't have it already. If you're using Java, Sun has numerous JTAPI resources on their site as well (http://java.sun.com/).
ipitts Mon, 08/18/2003 - 13:55
I agree. It is a TAPI item. You can monitor the status of the phone and when an I/O call is connected send the phone an XML execute
