Warning message
Installing Unity 4 w/ Exchange 2k into AD (w/ Notes)
Jul 28th, 2003
We are installing Unity 4.0(2) with Exchange 2k for voicemail only usage. Unity & Exchange will be on the same box and it will house roughly 50-100 voicemail users for now. We are planning on attaching the server to our AD network but need some information on caveats/recommendations for our situation. Our domain is using Domino/Notes for email without any exchange tie-ins. Our concern is bringing Exchange 2k into our environment (without a connector to notes) and what the implications are in doing so. We are concerned on what exactly Exchange (including forestprep and domainprep) will do to our domain, schema and current email users. Also, if we do bring exchange on-line with our domain, how will users be allocated/created for Notes email usage and Exchange 2k voicemail usage.
Any suggestions/comments would be greatly appreciated.
Todd
kechambe Mon, 07/28/2003 - 08:01
  • Gold, 750 points or more
Exchange 2000 and Domino are both autonomous products. They will not have any interaction with each other. Adding Notes users will not change. To add Exchange users you can have Unity create them or you can create them through AD Users and Computers and then import them in to Unity.
Running forest prep will cause all of your GCs to rebuild which will result in a ton of replication traffic. You might want to do this during off hours if you have WAN links between your GCs. Running domain prep adds the RUS service and a couple security groups. It's not nearly as intrusive as forest prep.
Hope this helps,
Keith
