Warning message
Licensing/dongles/staging question
Answered Question
Jul 28th, 2003
  • Silver, 250 points or more
Long story short:
In prep for a major roll out a while back a number of dongles were purchased but never registered. We will be rolling out an updated version of Unity and will need to register and update the dongles. Some are still in the box, but some of the servers are already racked and stacked remote.
1. Can we upgrade the dongle on a server in the staging center and then send to the site?
i.e. Can we upgrade a dongle on a server other than the one it will finally reside on?
Thanks!
Correct Answer by uversave about 14 years 3 weeks ago
Yes you can do that. Also please note that in 4.0 we do not use dongles anymore so if you mean by an updated version 4.0 you will have to contact your local Cisco Account Team on this.
Kind Regards
Ullie
Overall Rating: 5 (1 ratings)
Correct Answer
uversave Mon, 07/28/2003 - 11:37
  • Cisco Employee,
Kind Regards
Ullie
